Wheel bolt pattern
Does anybody know what the wheel bolt pattern is on my 95 ram 1500 two wheel drive. I'd like two know if i could use some of the newer twenty inch rims off of the newer rams somebody told me it was 5 x 5.5 but that is the ford truck pattern i know, is it 5 x 5 ?
Here ya go. Maybe this should be put in a sticky somewhere?? http://www.vehicle-bolt-pattern.com/...nce-guide.html
Your bolt pattern is 5x5.5, the newer rams are 5x5.5.
Problem is your 2wd, so you have your wheelbearings in your rotor vs. having a hub unit and then a rotor, this is were you run into clearance issues
To run the newer 20's you will have to run a spacer on the front rims, how big I dont know there is a couple people that have used spacers and it seems they all used different sizes, never really got a straight answer.
(it is said that the 02-05 polished aluminum rims will work without spacers)
Thats what i got for ya
just and FYI 97 and older ford 150's used the same 5x5.5 bolt pattern
and chevy is who used the 5x5 bolt pattern on the obs trucks
