Installing New APS Plenum Kit
Old Jul 1, 2010 | 11:32 AM
BigredRyder's Avatar
BigredRyder
Default Installing New APS Plenum Kit
Like the title says, I'm installing a new APS Billet Plenum Plate Deluxe Kit (99 Ram 5.9). Is there anything else when replacing the plenum that I should make sure is new as well like the pcv valve? Thanks.
Old Jul 1, 2010 | 11:50 AM
mnewbolds's Avatar
mnewbolds
Heater bypass hose, Torque to yield bolts, thermostat, check and clean egr, oil change when your done. I ran it then changed it again in 5 miles, still had coolant in the oil. Now would also be a good time to change the cap/rotor and cam positioning sensor. Just easier to access. GOOD LUCK!
Old Jul 1, 2010 | 02:34 PM
1998ram5.9's Avatar
1998ram5.9
wait, so if ur plenum gasket goes, the antifreeze can get in your oil?
Old Jul 1, 2010 | 04:33 PM
No, when you remove the intake manifold, you get coolant in your oil.
pcfixerpro's Avatar
pcfixerpro
No, he must have had another issue.
Old Jul 1, 2010 | 09:02 PM
mnewbolds's Avatar
mnewbolds
No, when you pull the intake the coolant runners still have coolant in them, gravity brings it into the engine through the valley. Hense... Change the oil.
Old Jul 1, 2010 | 10:50 PM
J415's Avatar
J415
I thought you were suppose to drain 2 gallons of coolant out before you remove the kegger?
Old Jul 1, 2010 | 11:19 PM
Coolant hides though. It waits for you to give it an escape, and then runs into the places you least want to see it. Coolant is just like that.
Even draining it down, there is still a good possibility some will be trapped in a location likely to cause you trouble. I think the engineers design them that way.
Old Jul 1, 2010 | 11:58 PM
Bubba39047's Avatar
Bubba39047
novice question. i have the v6, should i be as worried about my plenum as yal v8's? and if so how do i check if its bad?
Old Jul 2, 2010 | 03:46 AM
BigredRyder
Excellent. Thank you!
