View Poll Results: Should I do the Plenum gasket/kegger mod or Timing chain
Plenum Chain/ Kegger Mod
66.67%
Timing Chain
33.33%
Voters: 6. You may not vote on this poll
Which one should I do first?
Old Jul 5, 2010 | 12:19 PM
Rebhays27's Avatar
Rebhays27
Originally Posted by Sheriff420
Make sure you lay all the tools you'll need on the cowl before you crawl in there, it sucks having to hop in and out of the engine because you forgot a tool.
I think it's 10mm, 12mm, 13mm, 14mm, 1/2", 9/16" sockets and 1/2", 12mm, 14mm, 9/16" wrenches. and a 3" and 6" extension.
Some needle nose pliers (to get the wire harness off the valve cover if it's stubborn).
Some channel locks.
A flat head screwdriver to disconnect the throttle cables from the bracket.
A sharp pocket knife to cut the bypass hose off.
One of those razor blade scrapers that looks like a screw driver.
Plenty of paper towels.
Sheriff you sure you don't want to throw in a 15mm just to complete the set if I forget a wrench that's why I have a teenager!
Old Jul 5, 2010 | 12:25 PM
Maxx_Magnum's Avatar
Maxx_Magnum
dammit sheriff, I called dibs on that plate when you first posted about it failing
Old Jul 5, 2010 | 12:26 PM
J415's Avatar
J415
I told myself after rebuilding my tranny, that I would have to tighten my belt and not spend so much on my truck for a while. But since you guys are SO DAMN GOOD at convincing me, I'll to wait and do both. so what timing chains have you guys used?
Old Jul 5, 2010 | 12:27 PM
dodgeram07's Avatar
dodgeram07
i have a JP Performance Timing Chain
Old Jul 5, 2010 | 12:29 PM
Sheriff420's Avatar
Sheriff420
You're lucky, It's a miracle if I can get someone to help me with my truck, even something as simple as talking to me or handing me a wrench.
And yes, you do need a 15, the belt tensioner is a 15mm.
Maxx, I don't remember that. J415 send me a PM about it and I thought that was the first claim to the plate. Sorry.
I am kind of thinking it was the PCV dumping oil into the intake too because of the cruddy oil on the inside of the port that it is connected to, so that felpro gasket is probably fine to use on the plenum. Then again, Hughes says that they've never heard of a problem with the metal compression gasket leaking.
Old Jul 5, 2010 | 12:34 PM
J415's Avatar
J415
I don't have any kids yet, but I do have a crap load of nephews. The sad part is there either to young or to lazy so it's just me and whatever common sense survived my teenage years.
Old Jul 5, 2010 | 12:55 PM
Maxx_Magnum
np sheriff I'll let it slide
Old Jul 5, 2010 | 04:26 PM
CPTAFW163's Avatar
CPTAFW163
It won't take that much longer to do them both at the same time since you'll already have the radiator shroud/fan off (so you can stand in the engine to get the intake off) and the accessory bracket.
Some channel locks.
I know it takes me about an hour to get my intake off now from popping the hood to having an exposed lifter valley since I've done it twice.
Cloyes is a good brand from what I've heard and I have one of their single roller timing chains on my truck now.
yeah, this would have helped a lot.
