AC compressor replacement
Old Dec 7, 2010 | 11:31 PM
nmanchester's Avatar
nmanchester
when you do it replace the acumulator and the o rings make sure you get the appriate oil that is needed, get one that has a leak detection dye in it that way if you have any problems down the road you will be able to find the leaks. after you put the new parts in take it to a shop to have evac. and recharged its simplier that way. plus since your goin to advanced auto, go online and seach for coupon codes and order parts online for in store pick up it will save some money that way. thats what i do
Old Feb 24, 2012 | 05:42 PM
miknwv's Avatar
miknwv
I'm getting ready to do this myself, and was wondering if it can be evac'ed with an air compressor and an air blow fitting on the end of it.
Plus, I read something about having to replace the condenser. Is this a must? Or is it just something that if I don't do, I'll be doing all of this again within a year?
Old Feb 24, 2012 | 07:31 PM
gdstock's Avatar
gdstock
No. It takes a vacuum pump to pull low enough. Condensoer is probably OIK, but change the drier any time you open an AC system. Most compressor warranties require new drier for comp warranty to be effective. You'll need a receipt for it.
