CAI or 14x3
Old Jul 6, 2010 | 04:22 PM
audioman10's Avatar
audioman10
i had that problem alot almost lost the old 318 a year back to it had to redo alot to the motor and i put cold air intake on put a sock on and built it a nice littl cocoon...
Old Jul 6, 2010 | 05:28 PM
97r/tram's Avatar
97r/tram
Originally Posted by ThirstyRam86
So i was wanting to do a different type of intake on my '00 1500... I didnt know which type to do because i like to go muddin', but in here in Wyoming bout the only time we get real mud it involves BIG puddles... Thats where I run into my dilemma, when I hit a puddle and get water up the passenger side, I seem to suck up water... So my question is, would the CAI be better at keeping the water out or would a 14x3??
I'm using a stock air box with the spectre cotton filter and kept my intake tube going to the fender and I've never sucked water going thru big mud holes.
Old Jul 6, 2010 | 08:19 PM
redheadhunter21's Avatar
redheadhunter21
Never had problems getting water with the stock system, but my CAI has no problems at all everyonce in a while I will get a little mud that will get past the the tube not much at all though, eventually I will spend some time and seal it.
But do not get a 14x3 for offroading, most of the people I know that going mudding and have a 14x3 or something similar just take their stock box with them, my suggestion is to get a sealed box there are a couple out there
Old Jul 7, 2010 | 12:11 AM
Originally Posted by UnregisteredUser
Short of submerging the passenger side to the top of the fender, I've not heard of the stock airbox sucking water. So maybe you are the crazy guy with the problem no one else has ever heard of...
The thing is: If you've got that problem it needs to be fixed because shattered pistons are a real downer.
But they look so nice on the end of those pretzels. I mean, rods.
Old Jul 7, 2010 | 12:46 AM
UnregisteredUser's Avatar
UnregisteredUser
Well, yeah, but then they're worthless as ash trays.
Actually, I've never seen a water-shattered piston with a bent rod under it. I suppose it could happen, but I've not seen it. The crap flying around in the cylinder can wreak havoc on the rings, valves, and spark plug, and all of that I've seen, but never a bent rod.
It could be I've not looked hard enough. And I never want to see it in an engine of mine, which is why I've sworn off open 14x3 filters. Amazingly, I learned the first time. Who knew that could happen?
Old Jul 7, 2010 | 03:12 AM
ThirstyRam86's Avatar
ThirstyRam86
Gee thanks... lol
Thanks for proving that its not just me... lol
So anyone have any ideas where to find a sealed CAI? saw one on Summit Racing that seals to the hood but not sure if that would do the trick... click on the large image... here>>>>http://www.summitracing.com/parts/SUM-239371/
Old Jul 7, 2010 | 03:18 AM
RamSport97's Avatar
RamSport97
I have an S&B intake, its in a sealed box, but it does pull air from the stock location.
Old Jul 7, 2010 | 05:23 AM
ThirstyRam86
So how does this work for you?? do you do any muddin?
Old Jul 7, 2010 | 05:47 AM
UnregisteredUser
Gee thanks... lol
I try to do what I can.
I can't speak to any of the many options available, but I do trust my K&N FIPK-II with the filter sock to keep the water out of my own intake.
I'd think though that if you're sucking water with the stock setup, you might not want the S&B because it draws through the same cavity in the fender as the stock intake that's already giving you trouble.
Old Jul 7, 2010 | 07:51 AM
Gotta agree here. What you need is to get your air intake HIGHER. A cowl hood that seals to a housing containing your 14x3 would at least get the inlet up a bit. If you have water running over the base of the windshield, I think you are "in too deep" anyway.
