1996 Ram front axle question
Old Jul 12, 2010 | 12:09 AM
SKOALRING96's Avatar
SKOALRING96
Default 1996 Ram front axle question
i have a 1996 dodge ram 4x4. it has a dana 44 front axle, i am going to order a ring and pinion gear set in the near future and i need to know if this axle is forward or reverse rotation
Old Jul 12, 2010 | 02:00 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
From what I've looked at it is a reverse rotation.
That is, if reverse has the diff on the drivers side, and forward has it on passengers side.
I may be wrong though...
Old Jul 12, 2010 | 11:20 AM
Aubrey's Avatar
Aubrey
I don't know but any decent place selling them ought to know.
Old Jul 12, 2010 | 07:48 PM
94Beater's Avatar
94Beater
Front axle is standard rotation. I just installed 4.88 in the rear and 4.88 in the front. All the work I did myself. I've never done axles. It was a learning experience. My Dodge is my second truck so it was sitting on jack stands for a month before I had all the pieces. I really took my time to do everything the best I could. Once the rear was done I put maybe 15o miles on it before I switched to the front. Front took a lot more work than the back. Its all these shims you need to keep track of. Rear just has adjustable rings. Anyway, I'll post some picts soon.
Rear R&P I got from Ron's Machining on EBAY, rest I got from Randy's Ring and Pinion.
It was a fun project. Be patient thou.
Good luck.
Old Jul 13, 2010 | 07:12 AM
olyelr's Avatar
olyelr
Yep, standard rotation. Make sure when you order you either get a new carrier for the front or use the thick gears. I say this because you stated you wanted 4.56 or 4.88's in a previous post, and the stock carrier (with 3.55's) cant handle normal gears with this low of a ratio... but any competent company should know exactly what your truck will need.
Old Jul 13, 2010 | 07:13 AM
olyelr's Avatar
olyelr
Yeah, that doesnt have anything to do with it. It depends on if the pinion is on the top or the bottom.
