towing 3500lbs with OD on or off on highway?
Old Jul 12, 2010 | 01:31 PM
rustynuts's Avatar
rustynuts
Default towing 3500lbs with OD on or off on highway?
2001 ram 1500 sport, automatic
I'll be towing a trailer with total weight 3500 lbs for about 8 hours freeway driving.
once it's up to 65 mph, and on cruise, can I turn OD back on??
Old Jul 12, 2010 | 01:34 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF.
No, I would highly recommend against it. OD is meant for no extra weight cruising. You put OD on with that kind of load, you are asking for transmission problems. Even if it is not now, definitely later down the road.
Old Jul 12, 2010 | 01:37 PM
rustynuts's Avatar
rustynuts
ok thanks, I'll leave OD off!
Old Jul 12, 2010 | 11:40 PM
dhvaughan's Avatar
dhvaughan
leave it off unless your destination is Monte's transmission shop in Summerville SC. Stock units have oiling and overheating problems with the OD unit.
Old Jul 13, 2010 | 07:06 AM
olyelr's Avatar
olyelr
As these fellas have already stated, I also highly recommend leaving the OD off while towing. The OD in these trannys are not designed for pulling any more than the weight of the truck itself... sometimes I think they cant even handle that
What I used to do to get out of the higher RPM's momentarily, is when driving down a long steep grade or hill I would slip it into to overdrive while it was mainly coasting. I'm not sure if this did any good or bad, but it kinda made me feel a little better.
Old Jul 13, 2010 | 11:27 AM
BlueBeast2's Avatar
BlueBeast2
I turn it off no matter how much weight I'm towing.
HA HA oyler i read your post and didn't look at the name, saw your sig and thought why is this guy posting in here he has a freaking 06 totally different truck
Old Jul 13, 2010 | 11:35 AM
Maxx_Magnum's Avatar
Maxx_Magnum
I turn mine off as soon as I start the truck, just habit now but I hardly EVER use O/D at all, towing or not.
Old Jul 13, 2010 | 05:33 PM
Kaldir's Avatar
Kaldir
Your MPG must suck.
Old Jul 13, 2010 | 05:50 PM
Relex's Avatar
Relex
Originally Posted by Kaldir
Your MPG must suck.
That's what I do. I just turn od on when I'm doing 55 or over. I get 9.5 mph highway the last time i checked.
Old Jul 13, 2010 | 07:17 PM
Maxx_Magnum
Your MPG must suck.
Yes they do, I drive a 360 Ram
