Cross member that mounts to the bottom of tranny
So I recently removed my transmission and had it rebuilt not Ive got it back in. But I cant seem to get the cross member to fit back in it was a pain to get out and seems like it will be worse to get back in. Anyone have any ideas that make could make it easier?
no personal experience, but i think the official tool is a frame spreader. unofficial tools are a big hammer, or drive in a 4x4 or maybe rig up a bottle jack or an old fashioned bumper jack to spread the frame rails a tad.
Is the rubber isolator(not correct name) still attached to the crossmember or the tailshaft?
Remove it.
The crossmember needs to be installed from above & pulled down into position.
Should still have enough room to slide it in sideways then pull down with the isolator off.
Get all 4 bolts in one end(dont tighten) then persaude the other side down & get the other bolts in
Or just do what dhvaughan suggested & spread the frame,,,,,cant believe I said that lol
Remove it.
Well, when I replaced mine, i just used a big *** hammer, put it in catty-corner, and hit the hell out of it until it went into place. could do that, then take a spud and line it up to the bolt holes.
