oil change intervals
Old Jul 14, 2010 | 01:17 PM
  #21
brettj2408's Avatar
brettj2408
You will never catch me running 25,000 miles on 1 oil change.
How many times do you change your filter during this 25,000 mile period?
Thats the biggest issue is filtering out the oil.
I know oil can last up to a year and not break down and amsoil can probably be used for 25,000 miles but you should be changing your filter every 5 k or so and topping off your oil.
Old Jul 14, 2010 | 07:21 PM
  #22
Racinfan83's Avatar
Racinfan83
Every 3000 miles. Religiously. Mobil 1 and WIX filter. I put 3k on it about every 2 months....
Old Jul 14, 2010 | 09:25 PM
  #23
LegendKiller89's Avatar
LegendKiller89
I change mine anywhere from 3-4k miles. And I use a semi-synthetic blend oil with a Mopar Filter.
Old Jul 14, 2010 | 10:46 PM
  #24
chromed95's Avatar
chromed95
holy hell 25,000 miles on an oil change! I'm impressed. That's got to be saving you money right and left
Old Jul 14, 2010 | 11:02 PM
  #25
brettj2408's Avatar
brettj2408
i was quoting pavement-hater that said they were going 25k on an oil change
Old Jul 14, 2010 | 11:11 PM
  #26
LegendKiller89
25k on an oil change. Do you rotate your tires inbetween oil changes at every 6k? Do you replace the filter every so often?
I thought I read somewhere that using Aimsoil they are ''good'' for 25k but they recommend changing the filter (Aimsoil filter) every 7-8k miles.
Old Jul 15, 2010 | 12:43 AM
  #27
army_greywolf's Avatar
army_greywolf
Mobil 1 Synthetic 10W30, wix filter.
Oil is changed every 15,000, filter is changed every 5K with a quart added and a tire rotation done, plus a grease job. Frackin' oil is expensive.
Old Jul 15, 2010 | 02:12 AM
  #28
pavement_hater's Avatar
pavement_hater
Amsoil used to say change filter every 6 months. Now they have extended service filters that last 25k.
Old Jul 15, 2010 | 02:47 AM
  #29
CappinHoff's Avatar
CappinHoff
Every 6months, whichever comes first. I change it in the fall and in the spring. Mobil 1 Full Syn and Mopar Oil Filter.
Old Jul 15, 2010 | 03:00 AM
  #30
jasonw's Avatar
jasonw
Site Moderator
Extended periods, sure... but I'd never run anything near the 25k mark. I change mine 5k-6k. The wife's is changed every 5k or a tad more, and thats when I change mine as well (she has the service reminder setup in her overhead console). By the time she has 5k, I usually have 5.5k-6k.
