Hard to push accelerator
Old Jul 19, 2010 | 01:09 PM
Annihilator_X9's Avatar
Annihilator_X9
Default Hard to push accelerator
Okay, so I removed my airbox and checked for oil in the intake. It was there. No big deal right, I know what to do. But ever since I put it back together my accelerator pedal is hard as hell to push and it won't go all they way to the floor like it should. WTF did I do to it?
When I stopped for gas I check the linkage and everything and it all seemed loose to me. Is there anything else I should check for?
TIA
Old Jul 19, 2010 | 01:12 PM
TheBigRedOne's Avatar
TheBigRedOne
Make sure the linkage on the throttle body isn't pressing against the airbox. If it gets reseated improperly that can happen.
Old Jul 19, 2010 | 01:15 PM
Maxx_Magnum's Avatar
Maxx_Magnum
and make sure you didn't pinch the throttle cable somewhere when puttin the airbox back on
Old Jul 19, 2010 | 01:20 PM
Annihilator_X9
Man this forum rocks. You guys are on top of it. I'll check those when I get out of work.
Thanks!
Old Jul 19, 2010 | 01:25 PM
Maxx_Magnum
haha np dude hope ya get it fixed
oh and welcome to df!
Old Jul 19, 2010 | 06:03 PM
Annihilator_X9
Figured it out! The cable from the accelerator wasn't underneath that black plastic "tensioner" or whatever piece that is on the TB. So basically, when the pedal was to the floor, it was barely pulling on the TB.
Old Jul 19, 2010 | 07:54 PM
TheBigRedOne
That's happened to me about every time I've taken my air cleaner off.
Old Jul 19, 2010 | 07:59 PM
iwhitne's Avatar
iwhitne
happened to me too
Old Jun 7, 2011 | 03:16 PM
goula2's Avatar
goula2
Thanks Annihilator....I found this tread...same thing happened to me. I tried everything!! I replace air filter...reset ACC sensor, gutted cat (which needed it). I was going to somehow tighten up the cable at the accelator. I read your post and fixed my problem in about 20 seconds! You guys are a great help.
Old Jun 7, 2011 | 03:30 PM
talthyren's Avatar
talthyren
Speaking of the air cleaner....what IDIOT designed that thing? Its the most god awful, pain-in-the-*** thing to put back on after removal...It never goes on unless you bang the **** out of it with a rubber mallet LOL....
I dread doing any work that requires me to take it off...
