OEM Off-road wheels on 2WD - Center Cap Interference
Old Jul 20, 2010 | 04:54 PM
gobbell1's Avatar
gobbell1
Default OEM Off-road wheels on 2WD - Center Cap Interference
Has anyone put OEM off-road wheels (see pic) on a 2WD? If so, how did you overcome the spindle interference on the front wheels?
My spindle/grease cup sticks out past the center cap of the wheel, so I had to remove the wheel center cap and taper the rotor hub so the offroad wheels would fit.
Attached Thumbnails OEM Off-road wheels on 2WD - Center Cap Interference-wheel.jpg
Old Jul 20, 2010 | 07:55 PM
dodgeram07's Avatar
dodgeram07
i bought/traded for a set they would not fit over the hub/rotor....so i sold them
the only way they looked that i could get them to work would to get a spacer, so i didn't
so you got them to work?
Old Jul 21, 2010 | 09:54 AM
Sheriff420's Avatar
Sheriff420
You could just get a 4x4 for the rims
Old Jul 21, 2010 | 09:57 AM
gobbell1's Avatar
gobbell1
I got them to work, by slightly tapering the hub.
Old Jul 21, 2010 | 10:19 AM
RamSport97's Avatar
RamSport97
You can use low profile chevy bearing dust caps. They have a dome shape and are polished. I don't know the correct part number off the top of my head but I saw it on another forum and you can pick them up at Advanced Auto or Autozone. A lot of the 2WD guys that put 3rd gen 20's on use them. Might be worth looking into.
Old Jul 21, 2010 | 10:40 AM
gobbell1's Avatar
gobbell1
Thanks for the low profile tip. I also may shave 1/2" off my spindle as it is not needed anyway.
