"Higher Mileage" Oil?
Old Jul 22, 2010 | 07:42 PM
CPTAFW163's Avatar
CPTAFW163
Get whatever oil you want...JUST ADD LUCAS OIL STABILIZER. THat stuff is the best. It has anti foam in it so you won't get that caked on sludge (Caused by the foam sticking to parts and BURNING onto them).
I should have taken a CLOSEUP picture of my valvesprings when I did my 1.7s. They are PRISTINE. ANd that truck has been running mobil 1 or some synthetic for its life. I use 1 QT of lucas oil additive and that helps your engine a lot. Engine restore is not good, do not use that.
Here is a pic of the valvesprings and valvetrain assembly. Look closely and you will see how clean they are.
--Dan
Old Jul 23, 2010 | 02:49 AM
lastrights's Avatar
lastrights
they look sexy
Old Jul 23, 2010 | 10:56 AM
03neonSE's Avatar
03neonSE
Wish my heads would look that clean.
Old Jul 23, 2010 | 04:50 PM
charlie1935's Avatar
charlie1935
Those heads look bone dry, like they have never been run and gotten oil up in them.
Just my observation.
Old Jul 23, 2010 | 05:42 PM
revvinram's Avatar
revvinram
I personnally have used Lucas alot in a few of my vehicles in the past, I do remember reading something on another forum that wasn't to pleasing. I havn't used it in my Dodge since I have had it. http://www.bobistheoilguy.com/images/lucas/lucas.htm
Old Jul 23, 2010 | 06:47 PM
atc250r's Avatar
atc250r
I've read somewhere that the only difference bteween high-mileage oils and all the others is that H-M oil has "seal-swelling" additives to prevent/cure oil leaks. I don't see a need for it.
Old Jul 23, 2010 | 08:42 PM
lastrights's Avatar
lastrights
i heard lucus is heavy and wont make its way up kinda just sit in the bottom of the block
Old Jul 23, 2010 | 10:16 PM
charlie1935
They used to say that about STP also but I used for years and as long you added it to a warm idling engine as per directions it mixed thoroughly.
Old Jul 24, 2010 | 11:32 AM
plott hound's Avatar
plott hound
ive got 260,000 km on my '96 ram 5.2.been using synthetic since the 100,000 km mark.mainly amsoil it seems real decent.just went to the amsoil 10 w-40 and have noticed an increase in oil presure.
Old Jul 24, 2010 | 02:40 PM
aftermarket's Avatar
aftermarket
I've just got mine done with Castol High Mileage....for the extra few bucks it's worth a shot I suppose.
