collecting data for different air cleaners, help appreciated
Old Jul 26, 2010 | 09:26 AM
  #31
PurplDodge's Avatar
PurplDodge
Its so hot here it might as well be the same temp ambient and inside the motor. No matter the air cleaner, its friggin hot@#$&*888888888888888888888888888888888
Old Jul 26, 2010 | 09:28 AM
  #32
I hear ya on that one. It has been unbearable up here lately...... and my truck hates it too. If it is 90* or above, it runs crappy, doesn't wanna shift, and generally is a drag to drive. Temp drops to 89*..... runs/drives just fine.
Old Jul 26, 2010 | 10:45 AM
  #33
aim4squirrels's Avatar
aim4squirrels
interesting website on old school mopar air cleaners:
http://www.nicksgarage.com/aircleaner.htm
Old Jul 26, 2010 | 11:36 AM
  #34
Silver_Dodge's Avatar
Silver_Dodge
Originally Posted by stands2p
correct formula for density of a solid.air is not a solid its a gas.one would need to ad in the ideal gas law when calculating VE tables.P*V = n*R*T.combining both equations you get density=P(pressure)/R(GAS/constent)*T(TEMP).speed density VE TABLES will be N(estimated)=PV/RT.VE table are calculated using this equation.VE tables are not the only thing that controls the fuel.you have heard the saying "hot air rise's".density,volume,mass are not all the same.MAF sensor is MASS air flow.not volume air flow.anyway cold air is free horsepower anyway you slice it
Yes, my bad you are correct. Density of air = pressure / (specific gas constant x temp).
However, I still contend (from my own experience) that our PCM's care more about MAP then about temp because I have had my IAT fail, and the truck only exhibited difficulties at cold start up, then some minor surging the rest of the time. Other then that, it ran fine.
I agree, cold air is free horsepower, but unfortuntaly on our trucks, it isn't much and you have to have significantly colder air to really make a difference due to the issues mentioned above and the fact that we utilize a plenum volume intake rather then a direct port intake.
Old Jul 27, 2010 | 08:26 AM
  #35
stands2p's Avatar
stands2p
yes iam ty.wont get into the other stuff.grab that cold air.motors like it.plus its free.the best part
Old Jul 27, 2010 | 09:04 AM
  #36
beefythedodge's Avatar
beefythedodge
i have built alot of high performance vehicles in the past, and my experience shows that you have to seperate the air cleaner from the engine bay with a physical divider. the stock unit (at least i my truck) does have that but it still sucks the hot air from inside the engine bay.
my plan is to build a functional ram air hood that internally plumbs to a high flow filter that sits in an enclosure sealed of by the closing of the hood.
i simply make a "door" in the side of this enclosure with a linear actuator on it. if it starts raining i flip a switch and the door opens so it sucks the dry air out of the engine bay.
a simple screen water trap will trap 99.99 percent of water vapor coming in. i have used this setup on three custom air intakes i have made. worked great, and imho the best and most user friendly way to get truly colder air for the truck to breath.
