highbeams wont turn off HELP!!!
Old Jul 25, 2010 | 11:08 AM
uscg89's Avatar
uscg89
Default highbeams wont turn off HELP!!!
ok i have a 2001 ram 2500 and i got in my truck this morning and my highbeams turned on, i never touched them so i wiggled the multifunction switch and nothing. i unplugged the dimmer switch and they wer still on, athen i unplugged the multifunction switch and they were still on, lol im lost im pretty sure it could be the headlight control module but i cant find it to test it. i do not have automatic daytime running lights. please help my boss is giving me liberty tommorow and i dont want to spend it on this.
thank ya'll
Old Jul 25, 2010 | 11:33 AM
Welcome to DF!
Grab the factory service manual available for download in the FAQ section. It has wiring diagrams, and all sorts of other stuff to help you figger out what is going on.
Old Jul 25, 2010 | 12:29 PM
uscg89's Avatar
uscg89
thanks ill give that a try the lights will only turn off if i pull the fuses
Old Jul 25, 2010 | 12:43 PM
uscg89's Avatar
uscg89
weres the headlight control module??????
Old Sep 5, 2010 | 11:07 AM
eddie1's Avatar
eddie1
Default same problem
im having the same issue in my 2000 dakota 4x4 4.7L. any ideas as ive pulled relays, and the mfs switch with the lights staying on and key off.
Old Sep 5, 2010 | 11:22 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You should post your ? in the Dakota section. But if you have a tilt steering wheel, sometimes the wires get F'd up in the column or the multi function switch or the headlite switch itself could be bad. I dont know about the Dak, but the headlite switch is a fairly common problem on a Ram.
Old Sep 5, 2010 | 03:02 PM
nocturnalsst's Avatar
nocturnalsst
Is it just when you turn your lights on that the brights come on, or are they always on no matter what?
I'd start by replacing the switch that controls hi/low beams in the column
