Trans question
Old Jul 29, 2010 | 09:17 PM
tcoz370's Avatar
tcoz370
Default Trans question
2001 Dodge Ram 1500 5.2L Extended Cab
Truck goes to park, reverse, neutral, drive no problem what so ever. However she wont shift outta first gear. Tried drivin around and getting it to shift by letting off it at different RPMs. Still stays in first.
Yes, I did do some research on the site. Nothing fit my problem 100% but some of the conclusions people came to for similar problems was to change the "govenor pressure sensor & solenoid" Anyone think that this is my problem or any ideas as to what it could be?
Just got a refurb PCM cause I had "No Bus" before...truck starts now and everything with the PCM just doesnt shift from first...maybe bad programming...are the shift points controlled by the PCM?
Feel free to throw any idea out there, thanks
Old Jul 29, 2010 | 09:21 PM
PCM Controls shifting..... any service engine lite? Did they give you a PCM for a manual trans truck? Where did you get the PCM from?
Old Jul 29, 2010 | 09:22 PM
RamSport97's Avatar
RamSport97
Post this in MonteC's transmission thread stickied near the top of the 2nd gen page.
Old Jul 29, 2010 | 09:29 PM
tcoz370's Avatar
tcoz370
Got the pcm from http://www.autocomputerexchange.com/. Yes the check engine light did come on. Dont have a code reader and napa was closed to go have the code read...I talked with tech support and they said they had that happen before and are sending me a different pcm ups 2 day
