lifting my truck
Old May 23, 2005 | 05:37 PM
bryced_d's Avatar
bryced_d
Default lifting my truck
i want to lift my truck by putting 2500 coils under my the front of my 1500......does any one know if i have to get shocks that are made for a 2 inch or 3 inch lift with them?...also will the 2500 leaf springs fit under the rear and if so will i have to get longer shocks for that as well?
Old May 23, 2005 | 06:46 PM
steve05ram360's Avatar
steve05ram360
Default RE: lifting my truck
yes, you'll need new shocks front and rear... I did the 3" lift shock on the front, and left the rears stock and they are bottoming out. I still need to swap mine.
the 2500 coils gave me about 2 1/2" of lift so if you want to level your truck out, put in 1" blocks in the back and you should be close. you may be able to get away without the new shocks in the rear if you do the 1" block...
Old May 23, 2005 | 08:46 PM
bryced_d's Avatar
bryced_d
thanx..........i need new shocks all the way around though........do you know if the 2500 leaf springs will bolt up tom my 1500......i figure they will but i would just like 2 know for sure.......because i would like to be able to haul a little more and have a little stiffer ride
Old May 24, 2005 | 09:36 AM
steve05ram360
I think the 2500 rear leafs are wide than the 1500's... you should check before buying...
Old May 24, 2005 | 01:58 PM
Silver_Dodge's Avatar
Silver_Dodge
ORIGINAL: steve00ram360
......put in 1" blocks in the back and you should be close.
Are you implying to add an additional 1" block on top of the stock block? I have read that this is very dangerous, and that if you need to change your block height, you are supposed to buy a single block that is bigger by the height needed, not stack blocks.
I've never done either, so I don't know for sure. Just what I have read in other forums and off-road magazines.
Old May 24, 2005 | 03:10 PM
steve05ram360
ya know... I didnt put mine in so I cant say for sure if it's a 2" block or 2" oversized block. But I do know like you said, it should be 1 block. you can have them custom made for driveshaft angles on large lifts. for more search over on pavementsucks.com.
Old May 26, 2005 | 01:53 AM
bryced_d's Avatar
bryced_d
ok.........i think that i am just going to go with an add-a leaf in the back, instead of the block if i need to level it out.........thanx for the advice though
