Sounds like it should for stock exhaust. So that is good. A bit of smoke is perfectly fine, if turns to a blue color is when you need to be worried. Looks like a nice clean truck man!
is that a 5.2, automatic, and 4x4 by chance? If it is, I think i can help you out with a cheap Mopar performance PCM (92 octane). I had it in my 1996 and took it out when I bought my 2001.
Yeah it is. Whats a Mopar performance PCM? Does that mean i always have to run super unleaded?
you don't need a 180 stat. Also, if super unleaded is 30 cents more per gallon, that is only 6 dollars more per 20 gallon fillup. ANd you get better gas mileage with the chip and running better gas. So it is really pennies.
