46rh trans from a 1996 v6 ram?
Old Aug 5, 2010 | 02:16 PM
tybuff's Avatar
tybuff
Default 46rh trans from a 1996 v6 ram?
just posted this in montec's thread, however on second thought it might be better suited on its own.
Hi i am new to the site, and have a 95 ram 1500 2wd 5.2l with a bum trans. Reverse is shot, however is still works in all forward gears. I am not familiar with transmissions, therefore have my eye on a replacement 46rh.
The guy that has the trans, says it came out of a v6 ram 1996 model. It is still attached to the engine, as the
truck was parted out. From everything i have read, this seems to be the wrong model of trans for that year and application. Can anyone sort this out for me?
Excuse my ignorance if i have anything wrong here. I just want to know if this will bolt up to my v8 without any issues.
Cheers.
Old Aug 5, 2010 | 05:23 PM
The 96 trans should be a 46RE, Maybe a 42 or 44RE, not entirely sure on that, but, in any event, it takes its cues from the PCM as to when it should shift. It won't work on your 95.
Old Aug 5, 2010 | 07:42 PM
J415's Avatar
J415
On a side note; I love taking trannys out of van. They are too easy to uninstall.
Old Aug 8, 2010 | 05:36 PM
lane's Avatar
lane
Hey i just emailed you about the truck i have. Thinking about selling it. It's a 94 2wd so should be a direct swap as far as i know.
Old Aug 8, 2010 | 05:50 PM
jasonw's Avatar
jasonw
Site Moderator
https://dodgeforum.com/forum/2nd-gen...smissions.html
There, in the FAQ, very last post. Thats the transmissions from year to year, although wiring changed quite a bit sometimes, usually every couple of years.
