99 ram 1500 oil burning
Old Aug 5, 2010 | 07:41 PM
memine's Avatar
memine
Default 99 ram 1500 oil burning
okay - so I am searching for something positive and not what i fear
my annabeth is a '99 with 253,000 miles and I am burning oil like nuts between 3000 mi changes - (2 or more quarts) - no leaking - just burning -
white smoke on start up for sure
is there anything I can do besides rings and valves?
is it new engine time? or do I go ahead and buy a newer used ram? I don't want or need the payment.
btw - just put my first rebuilt transmission in @ 252,000
hopeful even though I know I have gotten my monies worth from this truck...
Old Aug 5, 2010 | 08:08 PM
dodgeman52's Avatar
dodgeman52
have u done the plenum? or valve guide seals?
Old Aug 5, 2010 | 08:15 PM
dhvaughan's Avatar
dhvaughan
welcome to df.
i wish i had a $1 for everyone with a leaking plenum.
take a look at the search button at the top for about a million threads. fix it with the hughes plate. it'll take you about a day, maybe 2 if you're slow like me.
Old Aug 5, 2010 | 08:27 PM
UnregisteredUser's Avatar
UnregisteredUser
White smoke on startup is likely valve guides, and valve guides can easily cost you a quart every thousand miles.
Test and diagnose rather than throwing money under the hood.
Old Aug 5, 2010 | 11:48 PM
memine's Avatar
memine
Default plenum thanks
ok - so I can do the plenum kit -
but should I go ahead and do rings and valves since this is like open heart surgery?
or is this step inexpensive enough that I can do it once and get another 100k on this engine? and then do valves and rings another time...
thanks
Old Aug 6, 2010 | 03:15 AM
bigslick050's Avatar
bigslick050
Well hopefully and more than likely it is a bad plenum that is your problem. Order the Hughes Plenum repair with the new hardware. Whole thing shouldn't be more than $200 with shipping + your time to install. Lots of people on here have done this job, so if you run into a snag, someone will be able to post help. BTW, bad plenums are very common among our magnum engines...
Old Aug 6, 2010 | 09:00 AM
dodgeman52's Avatar
dodgeman52
i would do the plenum and then see what happens andif it still is doing it do the valve guide seals
Old Aug 6, 2010 | 09:18 AM
Maxx_Magnum's Avatar
Maxx_Magnum
maybe the trucks mad at you for callin it annabeth
j/k man, I came here to mention the plenum deal as well, verrry common problem here. Welcome to DF!
Old Aug 6, 2010 | 03:22 PM
memine's Avatar
memine
Default thanks - oil burning
ok -
thanks for input - ordering plenum kit today -
oh and btw - all my trucks are lil ladies - just feels right to given the name -
kind of like a sailor and his ship - ladies all.... ok well most of 'em any way..
thanks again for all the input
Old Aug 6, 2010 | 05:34 PM
dodgeman52's Avatar
dodgeman52
u also need intake bolts
