auto to manual
Old Aug 5, 2010 | 09:43 PM
Sniperinhisname's Avatar
Sniperinhisname
Default auto to manual
i've been looking around and i can't find what i'm looking for. I want a list of all the parts i would need to turn my 1999 5.2 4x4 auto to a manual
i know i would need the tranny (nv3500)
new driveshafts
maybe a transfer case?
clutch pedal assembly and clutch and connecting cables.
But what else would i need? and if at all possible i would want to know the price of it all if i did everything new. (reman. tranny)
i am tired of this piece of crap 46re and want something i wont have to worry about.
and i got a kinda decent knowin of what i'm doing. and what i don't know my pops does lol
so please gurus, help a brotha out lol
Old Aug 5, 2010 | 10:30 PM
lastrights's Avatar
lastrights
i would just look for the 5.2 5 speed, by all the money you put into making it a manul you could have got a truck ?
i know you could go find a 2500 with the 5.9 with the 5 speed hehe both cummins or gas
Old Aug 5, 2010 | 10:51 PM
dodgeman52's Avatar
dodgeman52
i thing he is right unless u have alot of time and money to spend it would be easier to get a new truck. if u could find a donor truck it would make ur life alot easier
Old Aug 5, 2010 | 11:15 PM
Pedal hangers. Pedals. Clutch linkage. Flywheel, clutch, pressure plate. Get the NV4500 trans. Its heavier duty. (there is no kill like Overkill....) Trans needs to be out of a 4x4. Transfer case, and driveshafts should be re-usable. I think. PCM...... Wiring harness...... Might be able to just mod your current harness though.... There are a few connectors that aren't going to be used after the conversion. If you get the connectors for the manual trans with the tranny, just repin what you need to, and splice in the connectors on the appropriate wires.
There are also miscellaneous things you will need.... clutch safety switch, and the wiring for that..... and I am still probably forgetting a couple details.
In all reality, for the money you would spend, you could indeed buy a truck that came equipped as you like from the factory..... I see lots of 'em on Ebay, Craigslist, etc.
Old Aug 5, 2010 | 11:34 PM
working4ev's Avatar
working4ev
My friend I plan to do this swap This site gives a vary good brake down of what goes into the swap.
http://www.pirate4x4.com/forum/showthread.php?t=719449
dodgeman52 is right your best bet is to find a donor truck that was in a wreck of selling for cheap. This is what I plan to do.
It can be done has been done all it tacks is money.
Parts you need
Tranny nv3500 or the nv4500 with a gas engine input shaft
Transfer case NP271
transmission mount and or the cross member
shorten your drive lines
Shifter and boot
Bell housing
Flywheel
Clutch kit
Slave and master cylinder (The clutch operates hydrological)
Clutch pedal bracket
The ECU from a 99 or newer truck that had the manual trans.
Now you need to think what are you going to do about the gage cluster and the steering column.
I might be missing some of the little things. But this is why i plan to find a donor truck and swap over everything.
