46RE trans problems
Hi everyone.
I am having some trouble with my 2000 Dodge Ram van 1500 5.2.
Transmission started slipping in 2nd. I couldn't really tell if it was slipping in 3rd because it was too hard to get past 2nd.
1st gear is pretty solid, and if I manuall shift from 1st to 2nd I still get slipping in second.
Reverse would shudder a little bit under a load or slight incline.
Long story short I tore the trans out and currently have it on the bench.
After disassembly, the pump specs were ok.
The front clutches seem ok with little wear. I haven't figured out how to disassemble the rear clutch yet.
The front and rear bands don't look too bad also, both have about 1/16" fiber on them.
I started disassembling the valve body and found the accumulator spring on the valve body broken and wrapped up into itself.
I'm just wondering if this was causing all of my problems from the start.
Any help would be great.
Thanks. Chris
Thanks. Chris
No, your thinking of the one in the overdrive unit...I'm drawing a blank on the name of that spring and it's gonna haunt me for the rest of the day.
Check out this link https://dodgeforum.com/forum/2nd-gen...smissions.html. Post #6 is video that should help plus links to a manual.
Dave
Dave
Thanks for all the info.
Dave that link was great and will prove helpful.
I still however can't figure how the front and rear clutch packs split apart.
heres a pic from that link showing the packs separated,...Do I just press the shaft out from the other assembly?
heres an edited pic.
Thanks again.
Thanks again.
Trending Topics
Thanks again.
Thanks again.
https://dodgeforum.com/forum/2nd-gen...nsmission.html
OK, I reached in and took loose the top snap ring that is the inside diameter of the drum, I got the pack apart and the clutches are so shot they were binding against the drive teeth preventing me from sliding the drum off.
Anyone in the Omaha, NE area with a good used 46RE?
