How to tell if you have abs
Old Aug 15, 2010 | 12:08 PM
Wickedwiggles's Avatar
Wickedwiggles
Default How to tell if you have abs
I have a 1996 dodge ram 4x4 1500. I am about to replace a wheel hub assembly on the front of the truck (passenger side) How can I tell if I need abs sensor....I didn't notice any sensors around the wheel, but I have an abs light in the dash can I find out by calling the dealership and giving them my vin? Or is there some obvious way that I just passed up.
Old Aug 15, 2010 | 12:17 PM
If there are no speed sensor wires on the front hubs, you just have rear wheel abs. 4wal will have a fair sized motor/controller under the hood, rwal just has what looks like a proportioning valve with a couple solenoids on it.
Old Aug 15, 2010 | 01:17 PM
J415's Avatar
J415
+1 The ABS system will be contained in the engine bay on the rear driverside by the hood hinge. If it's empty there, then you don't have 4 wheel ABS. If you have something there, then you, more likely then not, have 4 wheel ABS.
Old Aug 15, 2010 | 04:42 PM
Aubrey's Avatar
Aubrey
You can tell if you have abs by doing a few situps.
You only have rw abs. That's the little connector sitting on top of the pumpkin back there.
Old Aug 15, 2010 | 07:41 PM
dhvaughan's Avatar
dhvaughan
count the number of hoses and wires going to your front steering knuckles. 1 is the brake hose. if you have a second wire/hose thing, then you have front abs.
Old Aug 15, 2010 | 07:44 PM
dhvaughan's Avatar
dhvaughan
when you're young you have abs that look like a 6-pack. after you get old they look more like a keg. i like using squirrels' icon...
Old Aug 15, 2010 | 07:55 PM
Where's the crosshair?
