Shaking when accelerating
Old Aug 17, 2010 | 01:12 PM
th3rookie's Avatar
th3rookie
Default Shaking when accelerating
Hi,
When I stop at a light then accelerate, the truck shakes for a second or 2 (from 3 to 6 mph approx.) The guy who sold me the truck told me it was just the vibration rubber on the transmission mount that needed to be replaced. What do you guys think?
Thanks
Old Aug 17, 2010 | 01:18 PM
Maxx_Magnum's Avatar
Maxx_Magnum
Sounds like maybe a rear ujoint.... I just changed one in my wifes Blazer not long ago, it was doing the same thing as yours, vibration while accelerating...
welcome to df, where in canada are you from?
Old Aug 17, 2010 | 01:20 PM
th3rookie's Avatar
th3rookie
Thanks for the tip, I'll look into that. I'm from Quebec City.
Old Aug 17, 2010 | 01:26 PM
Maxx_Magnum
ahhh well hello neighbour I'm in NB
Old Aug 17, 2010 | 01:48 PM
J415's Avatar
J415
When mine shook as you described, it was because it was misfiring and needed a tune up.
Old Aug 17, 2010 | 06:20 PM
dodgeboy1979's Avatar
dodgeboy1979
+1 on the misfiring i had the same problem a while back, just a bad plug wire.
Old Aug 19, 2010 | 09:03 AM
th3rookie's Avatar
th3rookie
If it was misfiring, would that happen just by stepping on the gas in neutral, mine doesn't do it, only when accelerating from 5 to 10kmph.
Hi there neighboor !
Old Aug 19, 2010 | 09:58 AM
redheadhunter21's Avatar
redheadhunter21
Look under your truck at the rubber mount that connects to the tranny it is possible its worn out like the PO stated and just needs to be replaced
Old Sep 2, 2010 | 07:15 PM
th3rookie's Avatar
th3rookie
So after I spent 104.00$ on a new tranny mount, the problem is still here. The tran mount was due though...
Next step, ujoint and misfiring...
I forgot to mention that the truck was dropped by the PO of about 4 inches. Could it be the angle of the driving shaft ??
Thanks,
Tommy
Old Sep 2, 2010 | 07:33 PM
CappinHoff's Avatar
CappinHoff
+1
Before the rear u-joints going out shattered my t-case I had the same issue. Now that I have a new t-case and better yet new rear u-joints, no more shaking.
