this overkill?
Old Aug 20, 2010 | 09:56 AM
RM_Indy's Avatar
RM_Indy
Yeah thought he had a 52tb, get that too
Old Aug 20, 2010 | 11:43 AM
greenmachine's Avatar
greenmachine
2 Bar Map
Old Aug 21, 2010 | 11:18 AM
Salex007's Avatar
Salex007
so i decided to buy a stealth this year instead of these parts so passing link onto someone else
http://desmoines.craigslist.org/pts/1897849986.html
Old Aug 21, 2010 | 05:07 PM
CPTAFW163's Avatar
CPTAFW163
I almost impulse bought that combo. But, I had a BAD experience with used heads before (more than bad, horrible and nightmarish). YOu never know if they have been run HOT. Aluminum heads and heat don't go very well. Plus, you need new pushrods for the eddy heads, and god only knows what pushrods you need for those heads and that camshaft.
THey sent me pics of the gibson headers. They are rusty. They are the NON-ceramic coated stainless steel headers. But they are rough.
Old Aug 28, 2010 | 01:28 AM
greek911's Avatar
greek911
New Member
will that setup they guy is selling work well for a twin turbo setup?
Old Aug 28, 2010 | 03:39 AM
CPTAFW163's Avatar
CPTAFW163
yeah. it will work. Not sure on that camshaft, but getting the heads and roller rockers for 1100 is a deal to me.
BAD THING: you don;t know if the previous owner ran the engine hot. If he did, those aluminum heads will be worthless. you really can't mill that much off of them because they are 58CC chambers.
WHy do you want to do a twin turbo setup? Do you have a lot of patience, or is someone else doing that for you?
Twin turbo setups are pretty hard. YOu need to redo your whole rotating assembly with forged components and use ARP bolts on everything.
Be prepared to spend 1200 on ARP 12 point head studs (Head studs are necessary for that much boost). I spent that much on a NA SBC.
--Dan
