Dudes new problems
Old Aug 27, 2010 | 07:44 PM
Joey Buentello's Avatar
Joey Buentello
Default Dudes new problems
missing an alternator bolt and an accessory bracket bolt the one that goes in below the tensioner pully. And the tensioner pulley bolt will only screw in about 1/4 in hand tight then it gets really tough. So what I need to know are the sizes of both alternator bolts and the accessory bracket bolt. Almost done with my install. Bagged and tagged all the bolts and still wound up missing some.
Old Aug 27, 2010 | 09:19 PM
CPTAFW163's Avatar
CPTAFW163
instead of bagging the bolts, put them back in where ytou got them when you are putting down the accessory bracket.
Same happened to me, so I just kept switching them up until it felt right. you will figure it out yourself before someone tries to explain it. There is no way to explain it unless someone here takes off their accessory bracket, takes a pic and points out each bolt and where it goes on a picture.
Old Aug 28, 2010 | 05:20 AM
Joey Buentello
luckily 5 house down my buddy has a 2001 318 with all the info i need.peace
