dayum! i need help
Old Aug 21, 2010 | 02:43 PM
eyedontneedaname's Avatar
eyedontneedaname
Default dayum! i need help
well i was trying to figgure out why my 4*4 wouldnt work. so i started taking my cad cover off and low and behold, its just full of mud? i know this isnt right. it cant be, well ive neve had or worked on a front axle nor the cad system so just trying to figgure out where to start.
i know i need to buy a vacume shift motor and shift fork. those are just trashed. so im thinking of going with the posi lock.
but heres where i need help. i clean out all the mud and now the axles just bounce around inside of my axle casing. what the hell have i just done?
Old Aug 21, 2010 | 03:52 PM
Aubrey's Avatar
Aubrey
Wow. That's not good. Start ordering parts and tools.
http://quad4x4.com/Dodge%20Tools.htm
You've probably got trashed bearings and seals.
Old Aug 22, 2010 | 02:59 PM
dhvaughan's Avatar
dhvaughan
the axles are suspended in the tubes.
they slide into the side gears at the diff.
the passenger inner should have a bushing or bearing at the inside edge of the cad opening.
the passenger inner and outer fit inside one another using a second bushing.
the outer end of the axles bolt up to the knuckle.
so the axle tube is hollow, and all the mud and crap goes down the tube. at the inside end of the tube is the oil seal. this is supposed to keep the oil in and the mud out.
you need a complete cad, bushing, seal replacement. not too expensive if you shop around. i got the bushings from a jeep shop for about $5-10 each. get the good seals from napa (SKF) or advance (National). damn a timken seal !!!! crap..
Old Aug 23, 2010 | 07:37 PM
eyedontneedaname
thank you! you just explained what i neeeded, i looked all over the net and in the manual, stilll nada. i justy needed it in laymans terms.
well after thinking. im going with the posilock for sure. it just an extra $60 from the vacuum motor plus i need a shift fork also, and i think they come with one??
ether way i just like the mechanical aspect it more than price, and the fact that ill never need to worry about vacuum problems again. now i need to work on my evap system leak...
Old Aug 23, 2010 | 10:14 PM
Scottr1110's Avatar
Scottr1110
posi loc doesnt come with a shift fork had to swap it from mine to the posilock. Make sure u take your time and get it adjusted well because it will pop out alot if its not adjusted
Old Aug 24, 2010 | 01:32 PM
DDIRI's Avatar
DDIRI
you might Be interested in this
http://www.jeepforum.com/forum/f12/h...ite-up-595515/
That is if you wanted to save some money. I know its another forum but its the best write up I've found. Let me know how it goes as I will be converting mine over as soon as I finish my motor swap.
Old Aug 27, 2010 | 02:02 AM
eyedontneedaname
hell i blew the old motors head gasket at 155k so i bought a new one out of a '00 with 70k for $500. i have to fix this axel then gears. ill be happy
WHY IS THIS HOME MADE POSI LOCK NOT SET AS A DIY???
