speedometer and overdrive not workin
Old Aug 24, 2010 | 06:44 PM
andy_s273's Avatar
andy_s273
k well the speedo didnt do anything when i spin the gears so looks like a bad vss so i ordered one for not 53 but 18 at my local prtstore.... but the harness that hooks to the sensor...the white orange wires like you said may be damaged and tht might explain the reason for cut off but where can i get that input clip??
Old Aug 25, 2010 | 07:03 PM
andy_s273's Avatar
andy_s273
thanks so much guys i just replaced the vss and my overdrive and speedometer were back up!
Old Aug 25, 2010 | 09:26 PM
matty675's Avatar
matty675
great! guessing theres no probs with the wires then?
the napa part came with a new connector but it sounds like youve straightened it all out
Old Jul 31, 2011 | 07:06 PM
lilypadman's Avatar
lilypadman
ok i have a 94 1500 4x4 and i replaced the vss because my speedometer went out along with the four wheel drive. i cant figure out how to check the gears to see if they are bad any suggestions?
Old Jul 31, 2011 | 07:32 PM
Which gears? On the VSS? There are index marks on the housing the gear goes into, to get the right spacing on the gear...... Too little, and it won't go in, too much, and it still doesn't work.
If the gear is 'apple cored', it's bad. (teeth ground out in the center of the gear.)
Old Jul 31, 2011 | 08:12 PM
lilypadman's Avatar
lilypadman
yea on the vss and im having issuses getting to the gears do i have to tear the whole transfer case apart?
Old Jul 31, 2011 | 08:14 PM
lilypadman's Avatar
lilypadman
better question do i have to take the transfer case out or can i do it with it in the truck because im 800 miles from home and dont have a garage here
Old Jul 31, 2011 | 08:20 PM
The VSS is located on the output shaft of the transfer case, and the hole thing can be serviced without dropping the t-case. You can get the 95 service manual (which is going to be VERY similar to yours...) here. Procedure you are looking for is on page 21-280. They even have some nice drawings to help you along.
This is something you could do in the driveway in 30 minutes or less. Check both gears, both the one that comes out with the VSS, and the one on the output shaft. If either are worn more than you think they should be, replace 'em.
Old Aug 1, 2011 | 08:26 PM
lilypadman's Avatar
lilypadman
well my gears are out but i cant fnd any trieda few part stores, mopar and ebayand mopar was the only one with anything but the page is down any suggestions on where else to get them?
Old Aug 1, 2011 | 08:53 PM
have a look here. Make sure you get the right color.
Is the drive gear on the output shaft ok?
