There will be low end loss with either, I'm tired of hearing otherwise. You need a few supporting mods to bring that low end back (and then some), the Mopar PCM was the ticket with my truck.
Guess I will probably stick with my kegger intake until I decide what else to do with my engine. I don't want to explode with a bunch of money right now, just a little at a time.
have you even tried the airgap? i have it on my truck. and there was no low end loss. there was also no low end gain. and a small improvement from the 2k rpms and up. and no mpg improvement. my plenum was not blown when i switched out.
and there is a loss for sure on the low end with the m1. the m1 seems to work alot better in dakotas. alot less weight to get moving.
