Transmission questions
Old Aug 26, 2010 | 03:59 PM
The beast is reborn's Avatar
The beast is reborn
Default Transmission questions
Not sure if this is the right spot to post this but I need some trans help. Engine is not running yet, when AT trans is in P , back tires turn along with drive shaft, they take a little force but nothing excessive to turn. I don't thing this is normal - I'm really a novice at this stuff
Old Aug 26, 2010 | 04:06 PM
Got a transfer case? Is it in neutral?
Old Aug 26, 2010 | 04:13 PM
The beast is reborn
it's in 2h but I guess I should be looking at that to. its hard to shift and I can't get in N or 4L.
Old Aug 26, 2010 | 04:31 PM
If the drive shaft is turning while the trans is in park, there is definitely a problem there. If you have an open rear end, spinning one tire, will cause the other tire to spin the other way.... but the drive shaft should NOT turn......
Old Aug 26, 2010 | 07:21 PM
The beast is reborn
I have a limited slip diff( I believe -it's all stock 95 1500 4x4) So its looks like problems with my trans and tc
what would prevent my tc from shifting
Old Aug 26, 2010 | 08:23 PM
Low on fluid. Shift linkage borked in some fashion. Internal problems....... Check the easy stuff first.
Old Aug 28, 2010 | 07:10 AM
The beast is reborn
Everything seems to be shifting fine now after I got the transfer case shifting properly. Tks for the help
