What size is our tranny cooler line? 1/2 or 5/8
Old Aug 26, 2010 | 09:01 PM
CPTAFW163's Avatar
CPTAFW163
Default What size is our tranny cooler line? 1/2 or 5/8
I want to get this to "install" a tranny temp gauge:
http://www.dieselmanor.com/dm_products/DM-TRS.asp
It is meant for diesels, so i don't know if our gassers have the same size lines
--Dan
Old Aug 27, 2010 | 01:03 AM
dhvaughan's Avatar
dhvaughan
1500 is 3/8 inch.
Old Aug 27, 2010 | 01:12 AM
CPTAFW163's Avatar
CPTAFW163
figures. i knew that a part from a website named "Dieselmanor" would be a bit off.
Too bad. It would have been good not to have to train my tranny fluid that I spent about 65 dollars to fill :P JUST to put in a gauge.
Well, i will just put it in the tranny pan.
Old Aug 27, 2010 | 01:24 AM
2real2die's Avatar
2real2die
I say catch it in a clean pan
Old Aug 27, 2010 | 01:29 AM
CPTAFW163's Avatar
CPTAFW163
I was thinking the same thing. But my luck, a screw will fall in there without me knowing. I guess i can fix a wire mesh screen in the funnel.
OR
do it really fast and top off what comes out.
Old Aug 27, 2010 | 03:11 AM
2real2die's Avatar
2real2die
That could always work, just cover the bung with your finger and work fast.
Old Aug 27, 2010 | 08:59 AM
Jr. Mechanic's Avatar
Jr. Mechanic
I'd rather have the temperature gauge in the pan, anyways. For the fluid, don't waste it. Drain it into a clean tub/bucket and use some type of filter to put it back in.
Old Aug 27, 2010 | 10:39 AM
97r/tram's Avatar
97r/tram
3/8" lines for transmission. Make sure to buy transmission line instead of heater hose. Also use lots of hose clamps if you're deleting the checkvalve.
Old Aug 27, 2010 | 12:23 PM
TitanOneSeven's Avatar
TitanOneSeven
I use one of these when I drain the tranny.
http://www.autozone.com/autozone/acc...ier=94647_0_0_
Fish the hose down the dipstick tube and pump the trans fluid out into a clean container. Works great for when you need to drop the pan (and not want to spill the fluid everywhere) and for times like this when you want to save and reuse the fluid. It says special order a lot but any auto parts store has it, even walmart.
That temp adapter is kinda cool, but I agree with Jr. I would rather have it in the pan anyways.
