fog lights????
Old Aug 30, 2010 | 12:14 AM
nopower318's Avatar
nopower318
I have a pre-runner light bar on my truck, check sig, link http://www.n-fab.com/products/sfID1/.../productID/251
Old Aug 30, 2010 | 09:52 AM
Sheriff420's Avatar
Sheriff420
You could get some rectangle lights and put them between the stock fog lights
Old Aug 30, 2010 | 11:47 AM
HammerZ71's Avatar
HammerZ71
Originally Posted by notanexit7
That light bar on ebay is made by randy ellis and is the only light bar you can get for a 2nd gen. It's only made for the 2500's but they said you can make it fit a 1500, you just gotta drill holes. I just with they had directions on their site so I could see where to drill them and if it would be hard to do.
I would imagine then you could always pop a weld on them to the frame where they come in contact with it too. Only downside is you'd have to cut 'em off if you no longer wanted it on...
Old Aug 30, 2010 | 12:59 PM
Sheriff420's Avatar
Sheriff420
Situations like that will make you thankful that God made Albert J. Dremel's family tree.
Old Aug 30, 2010 | 03:17 PM
vinnys's Avatar
vinnys
Yes I have them for sale if you need them. jsimone@suffolk.lib.ny.us
Old Aug 30, 2010 | 07:49 PM
notanexit7's Avatar
notanexit7
I've got lights in the same holes. How did you put yours in? Mine are in pretty good but they like to shake and I'll have to re align them and I'm not sure how to keep them from moving.
Old Aug 31, 2010 | 03:59 AM
Sheriff420's Avatar
Sheriff420
You could make some new mounting brackets out of thicker metal, then they won't shake.
I cut the plastic tabs off the bumper and used those to hold my brackets on, then I put one bolt in the center to hold the plastic to the metal (since I cut the tabs that held it on there off).
