Intake manifold torque & idle/low rpm misfire/shudder?
Old Aug 28, 2010 | 12:43 AM
master tech's Avatar
master tech
Site Moderator & Tech
TORQUE
TORQUE CHART 5.9L ENGINE DESCRIPTION N·m Ft. Lbs. In. Lbs.
Camshaft Sprocket Bolt 68 50 —
Camshaft Thrust Plate Bolts 24 — 210
Timing Chain Case Cover Bolts 41 30 —
Connecting Rod Cap Bolts 61 45 —
Main Bearing Cap Bolts 115 85 —
Crankshaft Pulley Bolts 24 — 210
Cylinder Head Bolts
Step 1 68 50 —
Step 2 143 105 —
Cylinder Head Cover Bolts 11 — 95
Engine Support Bracket to Block Bolts (4WD) 41 30 —
Exhaust Manifold to Cylinder Head Bolts/Nuts 34 25 —
Flywheel Bolts 75 55 —
Front Insulator Through bolt/nut 95 70 —
Front Insulator to Support Bracket
Stud Nut (4WD) 41 30 —
Through Bolt/Nut (4WD) 102 75 —
Front Insulator to Block Bolts (2WD) 95 70 —
Generator Mounting Bolt 41 30 —
Intake Manifold Bolts Refer to Procedure
Oil Pan Bolts 24 — 215
Oil Pan Drain Plug 34 25 —
Oil Pump Attaching Bolts 41 30 —
Oil Pump Cover Bolts 11 — 95
Rear Insulator to Bracket Through-Bolt (2WD) 68 50 —
Rear Insulator to Crossmember Support Bracket Nut (2WD) 41 30 —
Rear Insulator to Crossmember Nuts (4WD) 68 50 —
Rear Insulator to Transmission Bolts (4WD) 68 50 —
Rear Insulator Bracket Bolts (4WD Automatic) 68 50 —
Rear Support Bracket to Crossmember Flange Nuts 41 30 —
Rear Support Plate to Transfer Case Bolts 41 30 —
Rocker Arm Bolts 28 21 —
Spark Plugs 41 30 —
Starter Motor Mounting Bolts 68 50 —
Thermostat Housing Bolts 25 — 225
Throttle Body Bolts 23 — 200
Torque Converter Drive Plate Bolts 31 — 270
Transfer Case to Insulator Mounting Plate Nuts 204 105 —
Transmission Support Bracket Bolts (2WD) 68 50 —
Vibration Damper Bolt 244 180 —
Water Pump to Timing Chain Case Cover Bolts 41 30 —
Old Aug 28, 2010 | 10:22 AM
keen's Avatar
keen
Originally Posted by CPTAFW163
unless the rear gasket from the intake manifold shifted. i am talking about the little balck one with the dip in it that goes around the distributor divit in the block.
I've thought about that. But wouldn't it only cause an oil leak? that area only opens into the valley, not to the manifold or runners (at least with a good plenum gasket.. ). Right?
Old Aug 28, 2010 | 10:37 AM
dhvaughan's Avatar
dhvaughan
it might not leak oil... the oil would tend to drain down the valley rather than leak out the back.
however, that is an oil gasket, and not an vacuum/plenum gasket, so i don't think it would be a vac leak, even if it was completely missing.
