alternator
Old Aug 28, 2010 | 07:44 AM
The beast is reborn's Avatar
The beast is reborn
Default alternator
How do I check if my alternator is working properly?
Old Aug 28, 2010 | 07:53 AM
CappinHoff's Avatar
CappinHoff
While running pull the neg cable off the battery. If the car dies the alt isn't working. If it stays running it's working fine.
What issues are you having?
Old Aug 28, 2010 | 09:03 AM
Not sure pulling a battery cable is a good plan on these trucks......
Best test is to take it up the the local parts store, and have them put a load tester on it. Quick, painless, easy, cheap. And, no danger of pissing off electrical parts.
Old Aug 28, 2010 | 09:25 AM
jgcox6's Avatar
jgcox6
Take a voltmeter and measure across your battery while the car is running...you should see around 13.5 to 14.5 volts...
Old Aug 28, 2010 | 10:04 AM
charlie1935's Avatar
charlie1935
That worked on the older Mopars but I wouldn't do it on these computer controlled systems.
It could get very expensive.
