Spark Knock
Old Aug 30, 2010 | 07:25 AM
stonecaster's Avatar
stonecaster
Default Spark Knock
Hello all, I have a 98 Ram 1500 with 178K on it. A while back I started getting a loud spark knock and the check engine light would come on when I was at highway speeds, usually just trying to settle around 75 and stay there. If I gave it more gas or slowed down it would stop. I have changed the plugs, wires, rotor cap and rotor button. After all that it still did it. So I just recently changed all 8 fuel injectors. Now it is much much better but it still does it just a little bit, the check engine light will just flash at me now. Whats left to change? Like I said above other than on the highway this truck runs great.
Thanks.
Old Aug 30, 2010 | 10:04 AM
Check the plenum gasket. Look down the throttle body, and see what you see.
Old Aug 30, 2010 | 11:11 AM
95RAM360's Avatar
95RAM360
+1 the plenum is shot....you will need a kit from hughes or APS Precision, replacing the gasket will not fix the problem.
Old Aug 30, 2010 | 11:33 AM
FFFD827's Avatar
FFFD827
I had the same problem. check the TSB for your plug wire routing. if any of the wires are to close to eachother they will cross fire. i relocated all of my wires so none of them were touching, reset the computer and nomore spark knock of engine light. Takes about 15 mins and a bag of zip ties. try it you might be surprised.
Old Aug 30, 2010 | 04:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The plenum for sure, along with clogged cat,bad pre cat o2. Don't wait long to check theses items, the extra heat from a clogged or almost clogged cat will result in a cracked head.
Old Aug 30, 2010 | 09:42 PM
UnregisteredUser's Avatar
UnregisteredUser
While you're in there checking things, don't forget the PCV valve.
