Constant Oil Leak
Old Aug 30, 2010 | 08:16 AM
Annihilator_X9's Avatar
Annihilator_X9
Default Constant Oil Leak
Constant as in my truck has been sitting since Thursday and it's been dripping this whole time.
I did a search to see if I could get an answer and didn't find one. Like I said, my truck has been sitting since Thursday because I use a Cavalier as my daily driver. I looked this morning before I went to work and actually saw it drip. I'm wondering if there's a hole in my oil pan or something. I've never hit it on anything and it's been leaking since I bought it.
Any ideas? I thought it was the rear main but wouldn't that only leak while it's running and for a short period after I shut it off? I haven't been able to get underneath it and clean it up to see yet.
Old Aug 30, 2010 | 09:46 AM
Sheriff420's Avatar
Sheriff420
If it's the rear main then you will have an oil drop on the bottom of the transmission right behind the y-pipe.
Wipe up all the oil you can see and then check it after a while to see where it is coming from.
