frame cracked at power steering box.. help!!
Old Aug 30, 2010 | 03:35 PM
jsbige's Avatar
jsbige
Talking frame cracked at power steering box.. help!!
Hey, so I took my truck in for an alignment today only to find out that my frame was cracked following the inside along where the power steering box bolts up. Does anyone know of any premade patch kits that i can weld on over the crack with the holes and everything in their locations or do I need to fabricate one up myself? I got a buddy with a bridgeport milling machine and a bunch of welders so we can probably do it. I just want to make sure there's not an easier route. Any help would be greatly appreciated.
Old Aug 30, 2010 | 03:42 PM
GeorgiaDodge's Avatar
GeorgiaDodge
lets see some pictures so we can figure out what would be the best thing to do. maybe as easy as a patch or may have to box and sleeve the frame
Old Aug 30, 2010 | 04:08 PM
FFFD827's Avatar
FFFD827
Dont forget to stop drill the crack on both ends before you install your patch.
jsbige's Avatar
jsbige
Alright. Just took some pictures for you. Hopefully they help.
Old Aug 30, 2010 | 04:10 PM
jsbige's Avatar
jsbige
Sorry the pictures are so big. No idea how to downsize them, but for further clarification the crack is in the frame directly behind the rear bolt of the steering box.
Old Aug 30, 2010 | 04:19 PM
lane's Avatar
lane
go to image shack (just google it) and you can downsize there.
Old Aug 30, 2010 | 04:49 PM
Aubrey's Avatar
Aubrey
I've not heard of anything off the shelf for a patch so, you'll have to fab something up. After that you'll probably want to tie the two frame horns together.
Old Aug 30, 2010 | 09:38 PM
frazzler's Avatar
frazzler
the first thing you need to do is pull the steering box take a wire brush or grinder with a wire brush (do not use a grinding disk!!!!!) and see how bad the crack is. as far as drilling a hole at each end of the crack if you prepare your surface right this is not needed.I am sure your buddie knows this but just in case. if you need more help or advice post back
Old Aug 31, 2010 | 03:33 AM
dakotas ram's Avatar
dakotas ram
common problem on 70s ford 4wds, never heard of it on a newer truck tho
Old Aug 31, 2010 | 10:09 AM
03neonSE's Avatar
03neonSE
I would put some extra support where the steering box is. But don't think it can't be fixed. It can be fixed, if you know a frame shop in your area they can properly fix it.
