???Build Sheet???
Old Aug 31, 2010 | 12:08 PM
kejobe's Avatar
kejobe
Default ???Build Sheet???
Got a build sheet for my '01 1500 4x4. There are "options" that I have NO idea what the h*ll they are. Anyone have any ideas? List of ???s at bottom of list.
According to our records, your vehicle was equipped from the factory
with the following:
Sales Code Description
*S9 Deluxe Cloth 40/20/40 Bench Seat
-AZ Agate
ACH Jeep 65th Anniversary Edition
ADJ Heavy Duty Service Group
APAS Monotone Paint
A05P 5.2L Engine(ELF)/4Sp Auto Trans(DGT)
BAZP 136 Amp Alternator
BCQP 750 Amp Maintenance Free Battery
BGJS Pwr Disc/Drum Rr Anti-Lock Brakes
CBEP 40/20/40 Split Bench Seat
CGDS Front Height Adjust Shoulder Belts
CGWS Next Generation Front Air Bags**
CGZS Passenger Air Bag On/Off Switch
CKJS Black Vinyl Floor Covering
CSPS Passenger Assist Handle
DGBS All 4-Speed Automatic Transmissions
DGT 4-Spd. Automatic 46RE Transmission
DHAP Lock-Up Torque Converter
DHKS Shift-on-the-Fly,231HD Transfer Case
DJCS 195MM Front Axle
DMDP 3.55 Rear Axle Ratio
DRBP Corporate 9.25 LD Rear Axle
EAAC All Engines
EAGC All Gas Engine
ELF 5.2L V8 MPI Engine
GACS Tinted Glass Windows
GFDP Rear Sliding Window
GNAS Rear View Day/Night Mirror
GPUS Manual 6 x 9 Black Mirrors
GVAC All Vehicles W/O Power Mirrors
HAA Air Conditioning
HGAS Hood Insulation
HGBS Dash Liner Insulation
I28S Route 28 - NS, Buffalo, NY
JAYS Instrument Cluster w/Tach
JCBS 120 MPH Primary Speedometer
JHAS Var Intermittent Windshield Wipers
JJAS Cigar Lighter
JJBS Dual Note Electric Horns
JJJS 12V Auxiliary Power Outlet
KRAP STRIPE/BADGE/MOLDING/COLOR
KTAP STRIPE/BADGE/MOLDING/COLOR
LDAS Underhood Lamp
LMAS Halogen Headlamps
LNJP Fog Lamps
LPES Cargo Lamp
MBFS Bright Rear Bumper
MCTS Bright Front Bumper
MDAP Front License Plate Bracket
MFDS Bright Grille
MHAS Black Windshield Moldings
MWDS Removable Tailgate w/Caliper Latches
MXBS Front Air Dam
NAA Federal Emissions
NBKP EVAP Control System
NFWS 26 Gallon Fuel Tank
NHBP Auxiliary Transmission Oil Cooler
NMCP Heavy Duty Engine Cooling
PB7A Patriot Blue Pearl Coat
QB7S Patriot Blue Pearl Coat
RAAC All Radio Equipped Vehicles
RASS AM/FM Cassette Radio
RCDP 4 Speakers
RDDP Fixed Long Mast Antenna
SBAS Power Rack and Pinion Steering
SCBS 2-Spoke Steering Wheel
SFBS Front Heavy Duty Shock Absorbers
SGBS Rear Heavy Duty Shock Absorbers
SHAS Front Stabilizer Bar
TBBS Full Size Spare Tire
TBMP Tire Carrier Winch
TYUS P245/75R16 BSW All Season Tires
TZHP Michelin Brand Tires
WD5P 16X7.0 Cast Aluminum Wheels
WLBP Steel Spare Wheel
WLZC All Aluminum Wheels
WMJP Center Hub
XBSS Pickup Box
XCMS Vendor Painted Cargo Box
XEFP Transfer Case Skid Plate Shield
YAAS Build To U.S. Mkt. Specifications
Thanks again for your email. Have a great day!
Sincerely,
Harry
Customer Service Representative
Chrysler Customer Assistance Center
___________------_______________-----------_____________
Ok here are the ???s:
Thought I had a Dodge Ram.
In seats, how?
WTF? The truck came from NY. Maybe??
I have no mouldings.
See above.
Is this invisible?
WMJP Center Hub
Which hub?
Oh, and I checked and checked, then checked again that I gave the correct V.I.N., I did. So, next question is how would I get the title changed to a Jeep Ram 1500 4x4?
Old Aug 31, 2010 | 03:40 PM
charlie1935's Avatar
charlie1935
It says rack & pinion steering on all of I think.
Makes me wonder how many other things are wrong on their build sheets.
Old Aug 31, 2010 | 03:51 PM
Salex007's Avatar
Salex007
here in Iowa its $55 for the license tag versus the like 500-600 for an SUV here so im happy with the truck
Old Aug 31, 2010 | 10:02 PM
kejobe's Avatar
kejobe
I live in Ohio but the lot I bought the truck from got it in NY just a few days before. Is there possibly something "special" about NY trucks that Dodge would give them their own code? Something on the order of Cali. emissions, only for NY?
Old Aug 31, 2010 | 11:02 PM
95RAM360's Avatar
95RAM360
on mine it had one for NH...its where the trucks are sent when finished in production.
Old Sep 1, 2010 | 12:40 AM
redheadhunter21's Avatar
redheadhunter21
The rack and pinion is a mistake on almost all build sheets, the NY is probrably were the truck shipped to originally, the badge molding stuff may have been sent with the truck to be put on at the dealership but not done or they are common things added on the truck, and I have seen quite a few mistakes on buildsheets and missing info so they are not the most accurate.
Even one guy got two build sheets at different times and had some stuff that were different on both build sheets
Old Sep 1, 2010 | 02:15 PM
kejobe's Avatar
kejobe
K. In other words, don't trust them too much. Thanks for clarifying.
