clutch pedal adjustment?
Old Sep 1, 2010 | 05:33 PM
sl2lover's Avatar
sl2lover
Default clutch pedal adjustment?
ok so drove home last night and it was a high end clutch the clutch caught at the top of the travel path get in the truck this morning the clutch now catches at the ground? the truck still shifts fine but i want too know if this is a mechanical or hydralic clutch? if its mechanical can i adjust the cable?
Old Sep 1, 2010 | 05:34 PM
sl2lover's Avatar
sl2lover
sorry it's a 1998 3.9 v6 1500 with about 160,000 miles on it
Old Sep 1, 2010 | 07:26 PM
JackJ's Avatar
JackJ
It sounds like a bracket came lose, maybe the pedal bracket. If I am reading it right. No matter if it is hyd or mech you can adjust the throw of the pedal. Get a haynes or a chiltons book and it should be in there.
Try grabbing the pedal and see if it moves up and down, if so i would lean to a lose or broken hanger.
Old Sep 1, 2010 | 07:28 PM
Hahns5.2's Avatar
Hahns5.2
Hydraulic clutch, not adjustable.
