to anyone thinking about heads
Old Sep 4, 2010 | 10:35 AM
talon6's Avatar
talon6
aim- i plan on getting the sct before i even install all the stuff. i mean i know the tune probably wont be perfect, but hemifever can send me another one or two after i get it up and running. and i have been doing alot of research lately and there are alot of dakota fast trucks using the cometics with the alum heads with good luck. and when running boost, i am pretty sure you want to keep your compression on the low side.
cptafw163-i already have the 1.7's.mods in sig. thats why i got the cam i did. so i could still keep them since they only have around 6k on them. and i have seen your posts on them and i really wasnt that impressed with the 1.7's. i mean there was a little gain there but not that much to brag about i didnt think.
i was kinda hoping rm-indy would chime in too. i know he is running these heads.
Old Sep 4, 2010 | 11:01 AM
talon6's Avatar
talon6
and i see that the ports on the edel heads are matched to the rpm intake. i wonder if they are the same as the ports on the hughes air gap that i have since its made by edelbrock too? trhat would be a nice bonus to getting the eddies.
Old Sep 6, 2010 | 02:26 AM
97ramnj's Avatar
97ramnj
hey how could i bump my compression on my 318? i wouldnt mind having 10.4:1 and get some more ***** out of it lol, what heads would you guys suggest, i have a hughes air gap manifold and i wana do 1.7's or keep the 1.6's and get a mild cam.
Old Sep 6, 2010 | 02:40 AM
Ugly1's Avatar
Ugly1
edit: oops repeat
Old Sep 6, 2010 | 09:49 AM
talon6's Avatar
talon6
you are talking about a complete engine overhaul. or something like a stroker.
Old Sep 6, 2010 | 11:17 AM
aim4squirrels's Avatar
aim4squirrels
You'd need new pistons to push the compression that high. You can mill the heads down to bump the compression a bit, or use thinner head gaskets, but you might have to change pushrod length as well, and you definitely need a tuning solution if you start tinkering too high.
Old Sep 6, 2010 | 12:57 PM
Ugly1's Avatar
Ugly1
I'd like to consider the thinner gasket. How does one determine whether accompanying pushrod length changes would be in order?
When I went from 11.5:1 to 13.5:1 piston s on my bike I was suprised to learn that jetting stayed the same. I guess it's since the higher comp piston isn't changing amt of flow. A new ignition map could be necessary to prevent detonation though if you can't afford the good gas.
Old Sep 6, 2010 | 11:43 PM
97ramnj's Avatar
97ramnj
damn i just got a new motor to lol, im not guna go tearing into a brand new motor like that. i would like to have a lil bit more compression though
Old Sep 9, 2010 | 02:42 PM
talon6's Avatar
talon6
well after losts and lots of research gonna go with the clearwater 2.02's. the edelbrocks will not allow me to use my non adjustable 1.7's. and i am not wanting to buy new rockers. plus i want that extra lift that they are gonna give me with the new cam. thats why i got the cam i did.
Old Sep 9, 2010 | 02:58 PM
lastrights's Avatar
lastrights
you cant run clearwater heads with 1.7 HS?
