Old Aug 6, 2015, 01:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Cooling System
Print Wikipost
Coolant temperature sensor confusion
Old Sep 3, 2010 | 02:55 PM
rwisaacks's Avatar
rwisaacks
Default Coolant temperature sensor confusion
I got a 1999 Ram 5.2L and the last couple of days my temp gauge has has been reading alot cooler than normal and the truck started smelling like it's running really rich. Now I'm kind of confused. Is there a sensor for the gauge and a separate sensor that talks to the PCM? Or, are the both combined in the same sensor behind the altenator? Thanks in advance!
Old Sep 3, 2010 | 03:08 PM
J415's Avatar
J415
There should be 2 separate sensors, if I'm not confused. If its running cooler then normal, it could be your stat stuck open.
Old Sep 3, 2010 | 03:21 PM
rwisaacks's Avatar
rwisaacks
I'll go check the thermostat first, I put in a new one(195*) a couple months ago when I got a new radiator. I hate taking out the thermostat, PITA.
Old Sep 3, 2010 | 04:33 PM
J415's Avatar
J415
Grind the tab on the housing so that next time it it'll be easier.
Old Sep 3, 2010 | 04:53 PM
rwisaacks's Avatar
rwisaacks
+1 on that. I didn't do it last time, so I did grind it off this time. The old stat looked good but I went ahead and went to Advance and got a new Stant Superstat 195*. Hopefully that's the problem. Thanks!
Old Sep 3, 2010 | 05:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Just so you know, a 99 only uses the one sensor for both the gauge and pcm.
Old Sep 3, 2010 | 05:52 PM
rwisaacks's Avatar
rwisaacks
Thanks Zman17, I think I'll change the temp sensor then, if the new t-stat doesn't change anything.
Old Sep 3, 2010 | 07:07 PM
zman17's Avatar
zman17
I'd do that too. That sensor doesn't go bad all that often like the Tstat.
Old Sep 4, 2010 | 05:16 AM
J415's Avatar
J415
Thanks for clearing that up Zman. Last thing I wanna do is give out bad info. I know my 97 has two. What year did they go to one?
Old Sep 4, 2010 | 06:04 AM
zman17's Avatar
zman17
Maybe some late 97's. But for the most part 98 and up.
