Starting my winter build sheet!
Old Sep 3, 2010 | 08:32 PM
dodgeramit_10's Avatar
dodgeramit_10
Talking Starting my winter build sheet!
I already have plugs, wires, cap, and rotor plate replaced. I have a full exhaust in, cold air intake, Hypertech Tuner, E fan, have 180 stat. Im looking at Winter fixes and parts. Im thinking 1.7 HS rockers, 52mm fastman, plenum, and possibly hughes air gap manifold. Im also going to make a custom front and back bumper and light bar for extra fun. Anything else I should do or add or change give me input please. Thanks
Old Sep 3, 2010 | 09:23 PM
CPTAFW163's Avatar
CPTAFW163
If you have a 5.2, then you will want to get the 50MM fastman.
ALso if you have the 5.9 and like low end power, get the 50mm fastman. I have that on my 5.9 (from my 5.2).
Other than that, the 1.7s and those fab projects seem good. Maybe brake shoes (especially if you have never changed them). And brake pads. my truck drives so much better with the brake shoes that i had replaced and when I replaced my brake pads.
--Dan
--Dan
Old Sep 3, 2010 | 10:01 PM
95RAM360's Avatar
95RAM360
maybe a cam lol?
Old Sep 3, 2010 | 10:03 PM
dodgeramit_10
I have a 5.9 I do some towing but I figured if I do rockers plenum and intake manifold Im thinking the 52mm would be good Im mostly looking for power and lots of it. I have newer front pads and rotors back ones should be changed. Im running 32 11.5 15 so my brakes take a beating trying to stop. As far as Cam goes Im ganna try and avoid big jobs for a while till I get a second truck so Im not laid up for a while. But it would be a sweet add. lol
Old Sep 3, 2010 | 10:08 PM
95RAM360's Avatar
95RAM360
good point....well maybe you can get some custom tail lights and such.....i know it wont give you power gains, but its not that expensive...
Old Sep 3, 2010 | 10:14 PM
dodgeramit_10
That will be all extra cash. lol I do plan on headlights taillights tailgate LED bar, maybe some cab lights. After I beaf my truck up I wanna light it up. Make it look cool. Is changing the fuel injectors really that easy? If it is would 24 be a good size?
Old Sep 3, 2010 | 10:20 PM
95RAM360's Avatar
95RAM360
changing the fuel injectors is VERY VERY easy....a 6 year old could change the fuel injectors....
Old Sep 3, 2010 | 10:23 PM
dodgeramit_10
Sweet Ill be adding that to my list. Probably along with fuel filter to. Being a 97 it probably wouldnt hurt.
Old Sep 3, 2010 | 10:28 PM
95RAM360's Avatar
95RAM360
fuel filter is in the fuel pump, its not servicable...you need to buy the whole pump assembly
Old Sep 3, 2010 | 10:33 PM
dodgeramit_10
Thats probably what I would have done anyway. But thanks for letting me know
