Need a good motor build on a budget.?
Old Sep 5, 2010 | 12:40 PM
ecrider08's Avatar
ecrider08
Decent kit?
Edelbrock 58cc Assembled Heads #61779HER0814ALHughes Camshaft (208º/214º@ .050" .512"/.520" Lift 114º LSA5409Hughes FI AirGap Intake Manifold Kit1560Stainless Steel Rocker kit & Poly Locks6440ProGear Double Roller, 3 keyway Timing Chain & Gear Set7011Hughes Cam Bolt & Washer7181MARP Head Bolts7371Edelbrock Gasket Kit 5260Hardened Oil-Thru Pushrods
Old Sep 5, 2010 | 03:25 PM
jhammond_82's Avatar
jhammond_82
not sure about YOUR budget, but for ME thats a wish list! hahaha!
Old Sep 5, 2010 | 03:43 PM
ecrider08's Avatar
ecrider08
haha ya i was just using it as a refrence im just trying to compare specs
Old Sep 6, 2010 | 05:09 PM
spankythedog's Avatar
spankythedog
everyone says that the throttle body spacers are worthless, but I did notice an improvement in gas mileage, which is why i got it. driving back and forth to austin every weekend.
Old Sep 6, 2010 | 06:12 PM
Salex007's Avatar
Salex007
the throttle body spacer is placebo effect then, our fuel injectors squirt right in their so really the throttle body spacer does nothing on our engines. For about 2 grand get a plenum repair kit or an M1 intake, EQ monster magnum heads, harland sharp RR, 53.6mm throttle body from hipotek and an sct tuner. That for sure will keep you happy. I expect over 240 RWHP from that set up.
