'96 Cargo Light
Old Sep 8, 2010 | 11:07 AM
mjonesjr's Avatar
mjonesjr
Default '96 Cargo Light
In my '96 Ram the cargo light doesn't work. The dome light comes on with the switch.
The bulbs have all been changed, just not getting power to the bulb; I have metered it.
Is there a fuse just for the cargo light?
Old Sep 8, 2010 | 05:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You talking about the light on the rear of the cab? If so, that works with the headlight switch.
Old Sep 8, 2010 | 07:38 PM
redheadhunter21's Avatar
redheadhunter21
Make sure you twist it all the way, and check for a short in the wiring because it uses the IOD fuse IIRC and the dome light would also not come on.
Its 2 clicks for the cargo light
Old Sep 8, 2010 | 09:48 PM
mjonesjr's Avatar
mjonesjr
Yea I'm clicking the switch over far enough, just not getting power to the light.
Is the cargo light the only thing on the IOD fuse?
Old Sep 9, 2010 | 12:37 AM
redheadhunter21
Sorry meant to put dome light would not come on, the radio and a couple other things use the IOD fuse, so I would have to say you either have a short or some junk on the connecters for the bulb, might just need to take off cover and clean up connections and maybe a wiggle of wires
Old Sep 9, 2010 | 07:25 AM
mjonesjr's Avatar
mjonesjr
I will look into that.
Old Sep 9, 2010 | 04:45 PM
zman17's Avatar
zman17
Or the headlight switch is bad.
