swapping 5.2 to 5.9 and have a few questions.. please help!!!!
i have a 98 with a 5.2 auto 4wd the tranny went bad so i bought a 95 4wd wit a good 5.9 and good tranny for cheap i want to swap the 95 motor trans ect.. into the 98 i have been looking at it and the wiring harness is WAY different.. what is it gonna take to put the 5.9 into the 98 ANY help woud be appreciated.. thanks
Yep, the 95 is OBDI, but, you can just drop the motor in complete, hook up your existing wiring harness, and reflash the PCM for the larger motor.
The trans simply will not work. 98 uses 46RE, 95 uses 46RH.... the computer will be WAY confused, and the truck will never run right.
I saw a truck that looked a lot like mine (though in worse condition..... maybe I should post pics...), but, it was a 95. Nothing off of that truck would work for me. (it was a half ton with a 318..... damn. cheap too.)
+1 on all that, but he's still got a problem. his initial problem was a 98 with a bad trans and a good motor. he's bought a trans/motor combo where there's no way in hell the trans is going to work. little point in replacing a 98 5.2 with an older 95 5.9. what he needs to do is sell or swap his 95 trans/motor for a 98 trans.
edit - no way in hell is too strong of a statement. you can put the the 95 46RH trans in and not connect up the 98 46RE wiring harness to the trans. the trans will work but the truck will throw a transmission related CEL for the rest of its life. your speedometer will also not work since its electronic. i don't know how the pcm will react to lack of speed sensor signal. it might work ok, i don't know. i wouldn't do it.
hey guys thanks for the info.. im prob just gonna sell the 95 beater whole and use the money to get a nice rebuilt trans for the 98.. anybody lookin for a standard cab shortbox 95 wit a 5.9??????
