looking to buy a 95 with 01 engine.
Old Sep 13, 2010 | 09:41 PM
edgaro's Avatar
edgaro
Default looking to buy a 95 with 01 engine.
Hey fellas, I am looking at a 95 ram 1500 that the owner says has a 5.9 v8.
Is this possible to swap an obd2 engine to an obd1 truck and have it run great. Its a 4x4 body has 170k plus. engine has like 80k.
here are a few pics of the truck. thanks for the help fellas.
Old Sep 13, 2010 | 09:51 PM
dhvaughan's Avatar
dhvaughan
yes you can do that swap. the block and heads are the exact same. the only difference is the intake and the sensors. if you put the 95 intake and sensors onto the 01 engine, it would be fine. you might also encounter an EGR/non EGR that could be blocked off or completely eliminated.
Old Sep 13, 2010 | 11:04 PM
edgaro's Avatar
edgaro
oh nice. that was exactly what the guy said. he used the fuel rail and injectors and removed the egr. thanks for the quick response.
Old Sep 14, 2010 | 12:24 PM
lreice's Avatar
lreice
Default White Handles
White handles look nice...how did you do it? Paint separately or with the truck?
Old Sep 14, 2010 | 12:46 PM
95RAM360's Avatar
95RAM360
as long as you use the tranny from the OBD2 as well....the 95's came with a 46RH tranny. and the 96 and up used a 46re....so those would need changing as well.
Old Sep 14, 2010 | 01:24 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The motor will bolt right up to an RH or RE tranny! Tranny has nothing to do with it if it's not being changed from the original one,The only difference would be the flex plate and harmonic balancer, if it currently has a 318 in it. And as long as you do what DV stated as far as the sensors and intake go. You'll be good to go. While you have the intake off, do the Hughes or APS plate upgrade to it. And put new precat o2 sensor(s) in it. Also make sure the cat is not clogged.
Old Sep 14, 2010 | 02:14 PM
lastrights's Avatar
lastrights
truck looks good with 170xxx ! ! welcome to the forum !
Old Sep 14, 2010 | 02:28 PM
zman17's Avatar
zman17
I read the OP's post again a couple times. I could be wrong,but, it seems like the work was already done by the PO. So yes is the answer to his question, and the OP should do a search here for "plenum".
Old Sep 14, 2010 | 02:30 PM
95RAM360's Avatar
95RAM360
ahhh, i understand now.....so you wouldnt need a pcm either
Old Sep 14, 2010 | 02:41 PM
zman17's Avatar
zman17
Not if you are just swapping motors, and do what DV and I said.
