rattle in the front end
Old Sep 17, 2010 | 05:44 AM
lennyb3us's Avatar
lennyb3us
Default rattle in the front end
I have this weird, what I would call rattle in the front end. Sounds like it;\'s coming from the Drivers side. I say weird because it It only happens going over bumps and sounds like a coffee maker percolating, it's really faint. ANY HELP??????
Old Sep 17, 2010 | 08:23 AM
Loose/broken shock, or sway bar link.
Old Sep 17, 2010 | 09:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could also be the infamous steering column bushing.
Old Sep 17, 2010 | 09:50 AM
lennyb3us's Avatar
lennyb3us
I just replaced the shocks, I'll check to see if they need to be torqued alittle. also check the links too. How big of a job is the steering column bushing?? I honestly didn't notice the noise before the shocks were done though. Thanks for the info.
Old Sep 17, 2010 | 10:21 AM
dakota_raven's Avatar
dakota_raven
my money is on the sway bar links....
Old Sep 17, 2010 | 03:07 PM
JohnnyZJ's Avatar
JohnnyZJ
if you just replaced your shocks, did you put the washers back in with the new shocks? your shocks are likely still loose............
get on there with a breakerbar on the ratchet; these guys say to torque it to 100 ft/lbs. mine still clunked at 100...... i think i ended up at 120ft/lbs...........
Old Sep 17, 2010 | 03:35 PM
lennyb3us's Avatar
lennyb3us
It's going up in the air right now I'll post the results.
