U joints
Old May 30, 2005 | 11:41 AM
opdw35's Avatar
opdw35
Default U joints
Did a search in the forums and my drivers side u joint is shot. What I didnt find was what brand I should get to replace them. Plan on doing the replacement of both myself, just wondering how difficult it would be or should i just pay someone to do it. Any input would be great. Thanks in advance.
Old May 30, 2005 | 04:38 PM
theshocker's Avatar
theshocker
Default RE: U joints
If you have a press it should be fairly easy. I don't so I had to have someone do mine for $330[sm=headbang.gif]. The good thing is that he replaced mine with greasable ones so hopfuylly I will be ok for a while. As far as brands I have no idea man, sorry!
Old May 30, 2005 | 07:58 PM
crusher135's Avatar
crusher135
u dont need a press btw its easy without one u either goto the store buy the c-clamp for u-joints or just use a socket the same size as the hole and pound them out its quite easy
Old May 30, 2005 | 09:17 PM
CrueltyCOF's Avatar
CrueltyCOF
Yeah, the socket method works sometimes. Sometimes, you can break the axle shafts ears if your not careful. I would try the socket method if I were you. If you find it too difficult, take it to a local mechanic. Don't take your whole truck, take the shafts and the new joints with you. Sometimes they will do it right there when you bring them in. And when I buy ujoints, for any Dana axle, I buy Spicer.
Old May 31, 2005 | 08:13 AM
crusher135's Avatar
crusher135
if the socket method dont work go get a c-clamp jsut for u-joints it will save u alot of money then goign to a mechanic shop
Old May 31, 2005 | 12:37 PM
zeekxxx's Avatar
zeekxxx
Damn I never thought of a c-clamp and a socket. I got a ton of those. I just had to do my u-joints and the stock ones were NOT greaseable. I made sure the new one is. I got mine through autozone.com. I bought the more expensive of the two. Unless you get the new one thats in the 4-wheeler mag this month all are about the same. Its a pretty rugged part and its hard to buy a crappy one unless you go super cheap. (If you buy from autozone make sure you get new hardware too. --> Might as well replace the little ring that holds it on also.)
Im going to look for the ujoint clamp that was mentioned. I never heard of that before. I like to do my own work when I can.
Old May 31, 2005 | 07:31 PM
crusher135's Avatar
crusher135
i live in british columbia and they have them at any tool shop just ask a person working
Old Jun 1, 2005 | 09:12 AM
opdw35's Avatar
opdw35
Thanx for the input everyone, lots of helpfull sugestions hope I can get it taken care of. Looking at getting OX u joints, they are pretty expensive but from what Ive read they hold up forever.
