Whats wrong now?
Old Sep 19, 2010 | 04:30 PM
dodgeramit_10's Avatar
dodgeramit_10
All the fuses are good, I have the wire cover black tube stuff over everything. The temp. sensor hasn't been tampered with sense I put it in. I suppose i'm ganna look a little more and see if I can't find anything out of the ordinary.
Old Sep 19, 2010 | 04:54 PM
dodgeramit_10
I think my switch is bad I found the problem but it is confusing to say I unplugged were I connected to the fuse and tried it again it works now but when I plug my on off switch it shuts off and doesn't work anymore. So my fan will work as long as my switch isn't plugged in im got a spare switch im ganna try when I get done wit work but its still weird.
Old Sep 20, 2010 | 12:05 AM
Pacmanloads's Avatar
Pacmanloads
I thought you said you ran direct power to it with no result ????? Am I missing something?
Old Sep 20, 2010 | 09:32 PM
dodgeramit_10
yea I did and i got nothing IDK why. but it was something with the relay like a fuse or some $hit like I said it was confusing as hell lol. Did you hook the A/C (green wire) to a Black with a white line?
Old Sep 20, 2010 | 10:08 PM
aim4squirrels's Avatar
aim4squirrels
Black with the white line is the negative ground wire. That's what Dodge uses as a signal, grounding the circuit. Are you using a controller? There are provisions for both positive signal and negative signal in the flex a lite controller units. If you plug into the wrong terminal, you can get weird things happening. Is the manual switch you a having trouble with wired in the positive or negative line?
Old Sep 20, 2010 | 10:25 PM
Pacmanloads
I just want to know .....If you run direct power to the fan does it turn?
Old Sep 20, 2010 | 10:28 PM
Pacmanloads
http://www.flex-a-lite.com/auto/160-168-99975.pdf
Old Sep 21, 2010 | 07:37 AM
dodgeramit_10
I think that might be my problem I in the negative instead of positive. I was told its the only black and with white line in the big wire harness next to my brake fluid container.
Old Sep 21, 2010 | 09:09 PM
dodgeramit_10
I think my relay got screwed up I got a new fuse because I wrecked the one that was in it my truck wasnt ran for about 6 hrs and I put the new fuse in and the fan turned on and wouldnt turn off unless I disconnected power.
