P0455 P0442 evap evaporative emissions leak fix
#41
I have a 2002 Dodge Ram 1500 with the 4.7 and I have these two codes present. I found that my gas cap was loose( thanks gas guy) so I tightened it. I also got under the truck and looked at the evap system and did fined a descent rip in on of the hoses so I replaced that. My problem right now is the codes don't reset so I'm assuming theres a hard fault some where but where do I start.? Thanks
#42
#43
#44
i had same issuse on my 01 1500 4x4 drove nuts , finally took the canister down to paint the bracket it was rusted lines look ok no visible cracks i carefully wrapped each line with eletrical tape and put on new clamps , it work i tryed all the above gremlins that every body says and it was always coming back on 3 months later no issuse ... you may try that in did work for me best of luck!!
#45
#46
Error code P0442/P0446
This forum was very helpful. My 2003 Ram 1500 had a check engine light on for monts. Even after the engine was replaced, the light stayed on. I took it to Aamco or a free test and they could never figure out what the problem was, just that the code meant an evaporative emissions leak (never trust them to diagnos the light again). Then came time for the state emissions test and the truck fails. So I buy a code reader (got one cheap from Harbor Freight) and checked the code myself. First code I read is P0446 (small leak). So I pull the evaporator and find no damage. I inspect the hoses and find nothing wrong. So I start with the cheapest part first, the pump. Got one for about $25 from Rock Auto. Replace the part, reinstall the assembly and the code changes to P0442. So I go to the dealer and order a new gas cap. Install the new cap and as an extra, I figure that I'll put hose clamps on all the hose endings even though they are flared fittings, just to be sure. Then I discover the problem I missed. There is a short, pre-curved, rubber hose between what looks like a large fuel filter on the side of the evaporator assembly, connecting to a hard line to the fuel tank. There was a split in this rubber hose in the bend where I couldn't see it. I felt it when I was installing the hose clamps. Bought a lenght of 5/8" hose, installed it, cleared the code. Now I'll have to drive for a while to see if this is the fix needed. But I think that this should do it.
#47
#48
I just finished replacing the cracked hose above the evap system.. How do i go about clearing the codes the proper way. I thought i saw you say something about it but am not sure if just disconnecting the negative battery would do or is there more to it?? Thanks
