rebuild done
Old Sep 18, 2010 | 11:12 PM
Joey Buentello's Avatar
Joey Buentello
Default rebuild done
everything works great she wasn't running for 20 min and I took her mudding. One question my gen light comes on when she idles when i hit the gas it ( the gen light)turnes off whaddaya think?
Old Sep 19, 2010 | 07:46 AM
Check your belt tensioner. belt might be slipping at idle, or, your alt might be getting weak.
Old Sep 20, 2010 | 04:04 PM
Joey Buentello
thats what i was thinking
Old Sep 20, 2010 | 04:14 PM
CPTAFW163's Avatar
CPTAFW163
Might want to check the ground. When I did my plenum, I forgot to connect the ground wire in the back of the alt and I had a GEN light. It would go on and off. the loop was around the little bolt on the back, but it was not tightened down with the nut.
Get the alt tested, ebcause that can blow an alt.
OR it might be you forgot to put the plastic connector on it. But that would give a GEN light ALWAYS.
Old Sep 21, 2010 | 12:23 AM
Joey Buentello
i'll check it out in the morning have some other stuff to do to it too.
